Library Ethernet code
sunyuanling1022
Posted on October 04, 2007 at 09:28
2 REPLIES 2
sunyuanling1022
Posted on May 17, 2011 at 09:39
Hi everyone.this is the part code of the ENET_Init(u32 operatingmode)
void ENET_Init (u32 operatingmode)
u32 i;
vu32 regValue;
ENET_MACConfig *MAC_Config;
ENET_MACConfig config;
/* Put the PHY in reset mode */
ENET_MIIWriteReg(0x0,MAC_MII_REG_XCR, 0x8000);
/* Delay to assure PHY reset */
for(i=0; i
regValue = (u32) i;
it means that the address of the PHY is 0x0;but the data which I read from PR20-XMC is 0xaa(PAD4:0 10101).when I think the address of the PHY is 0x00,I also can read ID of PHY(STE100P)and the ID is right.So what I wonder is that what is the address of PHY ,how to define ?In my evaluation board the Mf4:0 is 10111.I appreciate your help.
Best Regards
sunshan
sarao
Follow up question:
what is the proper amount of delay to assure that PHY has been reset?
The datasheet
http://www.st.com/stonline/products/literature/ds/6806.pdf
is not clear on this point.
Any help from ST would be appreciated.
-Jeremy
[ This message was edited by: jsarao on 04-10-2007 02:10 ]
