ipl_st7 indart library
jmpavageau
Posted on March 16, 2006 at 12:23
6 REPLIES 6
jmpavageau
Posted on March 15, 2006 at 13:56
Hi
I try to use the sample code in VB6 delivered with this library (downloaded from softec.com).
My application is based on ST7Lite
When I try to connect my ST7 and the indart-STX card (USB), I have the message ''Hardware protection key not found'' ??? what does it meens ?
If I use my favorite indart STVD7 and try to connect my ST7 card using the indart-STX it work !!! So, in my mind it is not a configuration problem... USB drivers for indart-STX are properly installed as with indart delivered application's all is fine ;-) !
But I need to use the ipl_st7 library to develop my own programmation module.
Help me please
Jean-Marc
________________
Attachments :
ipl_sample.JPG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzOz&d=%2Fa%2F0X0000000bVk%2FhluugDRR8KxRJG.Dm38lPeF0cNPCMxTljxeYWDzvb90&asPdf=false
sjo
Posted on March 15, 2006 at 18:43
It means you have to pay to use the library, or try and get a demo licence.
sjo
jmpavageau
Posted on March 16, 2006 at 10:02
I don't think so... this library is free, u can download it direcly from softec home page.
sjo
Posted on March 16, 2006 at 10:34
Free to download but not use.
This is mentioned in the user manal, it uses a usb dongle
sjo
[ This message was edited by: sjo on 16-03-2006 15:06 ]
jmpavageau
Posted on March 16, 2006 at 11:59
ur rigth :-W I haven't read this part....
Where I can buy this dongle ???
thanks !!!
sjo
You could always try the same place you downloaded the software from - www.softecmicro.com
Last time i enquired it is expensive.
Have you thought of a lower cose solution, ST programming API (free) and a RLINK programming tool, instead of the indart.
sjo
