2007-09-19 01:20 AM
Internal bootloader for programming external flash. Help me!
2007-09-17 06:55 AM
I've buit a STR710FZ2 kit, but i haven't had a hardware tool for programming External flash. I'm using a programmer with only 1 74HC244 buffer.
Anyone can help me an internal bootloader?!!! Regard! [ This message was edited by: henzaimz on 17-09-2007 19:26 ]2007-09-18 10:07 PM
I am not sure I understood what do you need exactly ....
can you explain please ?2007-09-19 01:20 AM
Thank you, Stefanie. I've solved my problem by using Str710-Eval Bootloader 1.0 downloaded from ST.
But now, with zimage.bin, i can't uncompress ucLinux Kernel :( All file have loaded successful, but the line: ''Uncompressing Linux ...... done'' didn't apprear. ________________ Attachments : notappear1.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtIV&d=%2Fa%2F0X0000000aLE%2F3JSqVpV8DyXNZ6XLTDTPOFDObhIwLZMQ1PZLU67xaqc&asPdf=falsenotappear2.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtIf&d=%2Fa%2F0X0000000aLG%2FiNGcZ10kYQuyC3XydWUFcOg.jYsAzy.mWE8_fvxiY.w&asPdf=false
