iap
shweta_arora
Posted on March 10, 2004 at 08:40
iap
shweta_arora
Posted on March 10, 2004 at 03:59
sir,
actually i want to erase /program 2 or 3 bytes at different locations in my s/w so i want to use iap for that.
can you pls guide me the way to perform this and if you could pls send me the related documents.
i am using '' st7flite02'' mc which does not have eeprom.
pls support.
i also want to retrieve the data written on locations.
thanks
best of regards
shweta
shweta_arora@elymer.com
ldefend1
Posted on March 10, 2004 at 04:41
shweta,
there are several application notes about that:
http://www.stmcu.com/files/mcu/9056.pdf
http://www.stmcu.com/files/mcu/An1576.pdf
Hope this helps
[ This message was edited by: friul on 10-03-2004 09:13 ]
jatin
For detailed info, you can also refer ''ST7 Flash programming manual'' which is downloadable from the same site.
[ This message was edited by: Jatin on 10-03-2004 13:13 ]
