IAP driver for IAR compiler
anil23
Posted on February 22, 2006 at 12:09
10 REPLIES 10
anil23
Posted on December 08, 2005 at 16:37
I was looking for some sample code if someone had the IAP driver running on the IAR compiler
anil23
Posted on December 12, 2005 at 14:19
Thanks a lot,
I have taken the task of porting the IAP driver on the USB. Lets see how successful i would be!
anil23
Posted on February 15, 2006 at 12:04
Hi Zouh,
I realized that the IAP driver files need to run from the RAM. But the linker file in the example doesn’t load the files to RAM. When I try to execute your code the file download is performed fine. But, when I try to program…it gives me an error that “There is no file to be programmed….� And after couple of seconds the terminal windows quits.
Please update me with the project/linker files of IAP driver for IAR.
Regards,
[ This message was edited by: iamanil on 15-02-2006 17:06 ]
anil23
Posted on February 15, 2006 at 13:54
Hi Zouhair,
Thanks for all your help.I followed your instructions and performed them on my STR710 board.
I can download the file now. But its not programming the internal flash(when i press 2 on the hyperterminal). It returns a ''E'' on the hyperterminal and returns to Main_Menu().
Please find attached the updated project and the file I'm downloading.
Also, the LED20 on the board is turning red after i download the program.
Regards,
[ This message was edited by: iamanil on 15-02-2006 18:26 ]
________________
Attachments :
IAP-IAR_v1.1.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtHN&d=%2Fa%2F0X0000000aL1%2FXTMpC8ezNSUHj0dASIBccUWecFFRYpIoPJmiUrwaa38&asPdf=false
STR710-Eval.a79 : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtHX&d=%2Fa%2F0X0000000aL2%2FkiCz3bQEEa_tMTCxS3uLDJZFZ4jYWU4aoGkT.G7skII&asPdf=false
anil23
Posted on February 15, 2006 at 15:42
Hi Zouh,
Yes! I did. I'm sorry for not mentioning that in my prevous message.
I did press 1 for download..it downloads the file fine and displays the file information (size and name of the file) on the terminal window.
Then, when i try to press 2, I get the message ''E'' and the program jumps back to Main_Menu();
If you could run the attached project and download the file attached fine on your MB 393 board . Please let me know.
Thanks,
anil23
Posted on February 16, 2006 at 16:39
Thanks Zouhair,
It seems to work now...I will let you know if i come across any problems.
Regards,
anil23
Posted on February 17, 2006 at 02:37
Hi Zouh,
Please help me understand the process for generating the binary file using IAR. Did you generate it under Project->Options->Linker->Extra Output->Generate Extra Output with output format as raw binary?
Please let me know.
Regards,
anil23
Posted on February 17, 2006 at 15:44
Hi Zouh,
I followed your instructions to generate a binary file from the IAR demo board example. I got a programming error while downloading to the flash.
Please find attached the project for your reference.
Regards,
________________
Attachments :
STR710-EVAL.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtHh&d=%2Fa%2F0X0000000aL3%2F0HRE2Me5_8rgIi44gG5bHKGAK5ffyW_omjZ3RscQEhQ&asPdf=false
anil23
Posted on February 21, 2006 at 20:34
Hi Zouh,
Thanks for the updated project. I have made a step forward in my attempts to make IAP work through the USB. It's working with the bin file for the example.
Regards,
