I need the technical specifications from a ST MOSFET
OKund
Hi I need the technical specifications from a MOSFET , A748, BUZ11
Ozone
Lead
Transistors/diodes with the same name use to have the same specs, regardless of manufacturer.
Licence production is quite common in the semiconductor business, especially with those bread-and-butter products.
If you do not load them with 100% of their max ratings, you will probably not notice any difference.
