I have a question about the COSMIC C complier
hongluo
Posted on December 27, 2004 at 02:10
5 REPLIES 5
hongluo
Posted on December 23, 2004 at 23:26
Hi!everybody!
I have a question about the COSMIC C complier.
When I use PA7^=1 and PA7=PA7^1,the disassembly is different.
The meaning that I think the two is the same.
But I don't understand why different ??
The following is my code ...and thanks.
Quote:
main.c:42 PA7^=1;
0x8083 0x0F0004 BTJF 0x00,#7,0x808a BTJF 0x00,#7,0x808a
0x8086 0x1E00 BSET 0x00,#7 BSET 0x00,#7
0x8088 0x2002 JRT 0x808c JRT 0x808c
0x808a 0x1F00 BRES 0x00,#7 BRES 0x00,#7
main.c:41 PA7=PA7^1;
0x8083 0x4F CLR A CLR A
0x8084 0x0F0000 BTJF 0x00,#7,0x8087 BTJF 0x00,#7,0x8087
0x8087 0x49 RLC A RLC A
0x8088 0xA801 XOR A,#0x01 XOR A,#0x01
0x808a 0x2602 JRNE 0x808e JRNE 0x808e
0x808c 0x2004 JRT 0x8092 JRT 0x8092
0x808e 0x1E00 BSET 0x00,#7 BSET 0x00,#7
0x8090 0x2002 JRT 0x8094 JRT 0x8094
0x8092 0x1F00 BRES 0x00,#7 BRES 0x00,#7
:-W
luca239955_st
Posted on December 24, 2004 at 06:42
how do you define PA7 and what version are you using?
The answer to your question is probably
When assigning an expression to a _Bool variable,
the compiler compares the expression against zero and assigns the
boolean result to the boolean variable.
See page 53 of the user manual for more details.
If, as I guess, you are trying to toggle a pin of PortA, your best option (smaller code) is to address the whole port at once, as shown in the exaple below:
[code]
_Bool
mailto:PA7@PADR:7
; 38 PADR^=1; (6 bytes only)
000e b600 ld a,_PADR
0010 a801 xor a,#1
0012 b700 ld _PADR,a
; 40 PA7^=1;
0014 0e0004 btjt _PA7,L6
0017 1e00 bset _PA7
0019 2002 jra L01
001b L6:
001b 1f00 bres _PA7
001d L01:
; 42 PA7=~PA7;
001d 0e0004 btjt _PA7,L21
0020 1e00 bset _PA7
0022 2002 jra L41
0024 L21:
0024 1f00 bres _PA7
0026 L41:
; 44 PADR=PADR^1;
0026 b600 ld a,_PADR
0028 a801 xor a,#1
002a b700 ld _PADR,a
; 46 PA7=PA7^1; (wrong, don't do it)
002c 4f clr a
btst _PA7
0030 49 rlc a
0031 a801 xor a,#1
0033 2704 jreq L61
0035 1e00 bset _PA7
0037 2002 jra L02
0039 L61:
0039 1f00 bres _PA7
003b L02:
[/code]
Luca (Cosmic)
hongluo
Posted on December 27, 2004 at 02:08
hongluo
Posted on December 27, 2004 at 02:09
Hi everybody,
I can't post the question in the forum.
So I write my question in the attachments.
And thanks again. :)
[ This message was edited by: hongluo on 30-12-2004 03:49 ]
________________
Attachments :
Question.txt : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0F3&d=%2Fa%2F0X0000000bVv%2FAxXij1IHK7fzpf.7xoYq_Igr42Sunl4aZ2oiLdu_c_0&asPdf=false
hongluo
