Help needed on simple SCI program... why don't I get the same result back
christophe2399
Posted on December 31, 2002 at 10:01
2 REPLIES 2
christophe2399
Posted on December 26, 2002 at 19:50
code :
.include $SetupFileName
segment 'Ram0'
.MB DS.B 1 ; variabele byte op adres 80h
segment 'Rom' ; Code segment - Address defined in device file (.str)
; Main Code here
.main
call ontvang
call wachten
call verstuur
call wachten
jra main
.ontvang
bset SCICR2,#2 ; RDI begint te zoeken naar een startbit
wacht btjf SCISR,#5,wacht ; Wait for reception of a new byte
ld A,SCISR
ld A, SCIDR
ld MB,A
ret ; RDRF = hoog als 1 byte ontvangen is
.wachten
ld X,#255
w2 ld A,#255
w1 dec A
jrne w1
dec X
jrne w2
ret
.verstuur
bset SCICR2,#3
ld A,SCISR
ld A,#$80
ld SCIDR,A
wacht1 btjf SCISR,#7,wacht1
ld A,SCISR
ld A,MB
ld SCIDR,A
wacht2 btjf SCISR,#7,wacht2
ret
.include $VectorFileName ; Interrupt and Vector file (.stv) included here
end
This program first accepts 1 byte from the PC and than sends back #80 and the received byte MB to the PC...
The problem is that do not get the value back that I've sent to the MCU.
What is wrong?
thanks
chill@mine.be
stephanie
the btjf SCISR,#x,wacht already performs an access to SCISR. You don't need to read it once again after the btjf, maybe this can disturb the communication. It's better to put the SCI initialisation in a dedicated routine (TE,RE can be set at a time cause SCI is full duplex).
I attach a file written in C but containing in-line assembly. Hoping it will help!
[ This message was edited by: stef on 31-12-2002 14:32 ]
________________
Attachments :
Sci.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0As&d=%2Fa%2F0X0000000bW3%2F24XX0rFzE81VMmOx6ePTmPyV9ar9N14pfx0VK6fvWD8&asPdf=false
