2005-03-04 02:12 AM
2005-02-17 07:49 AM
What would be the required hardware implementation for a true lan interface?
1st, i assume that we have to get a MAC range from XeroX 2nd, Some transformer ?? I'm using the pll just to suply usb clk, so i'll need a 48MHz new on.. :( Can anybody post a basic drawing?? Tia2005-02-22 07:05 PM
Hello ESPrado,
I can't understand what do you need exactly, what a range of transformer you want to execute; please can you explain you problem any more? :-? With regards, Hich. :-o2005-03-04 02:12 AM
Well, chip has HDLC, so fine
Intead of using the USB and external MAC Chip like Realtek'shttp://www.realtek.com.tw/downloads/downloads1-3.aspx?spec=True&compamodel=RTL8150L(M)
i was thinking in save MAC addres inside cpu flash and drive the LIN directly. Maybe some chip in between? Thanks for any advice [ This message was edited by: ESPrado on 04-03-2005 15:46 ]
