2005-08-09 05:43 AM
2005-08-04 02:01 AM
I am totaly disappointed. I have burnt the evalboard by a 12Volt power supply But, I am sure I am not the only one :). So I should change some components. I want to know which one? I have problem to find L9669 and L9616. Where can I find it or is there an equivalent component? Thanks, Ludo2005-08-09 05:43 AM
Hi Ludo,
You must change these components: -1- IC7: ST662A -2- IC5: L9669 -3- IC4: L9616 -4- IC19: 74LCX14 -5- LCD1-1: LCD2*16 Concerning problem to find L9669 and L9616 I suggest to contact ST- distributor I hope that STR710 work again :) With best regards, Punto
