HALT mode and wake up by ST7LITE
jermakov
Posted on July 10, 2007 at 17:40
jermakov
I need a help to create codes for enter to HALT and wake up procedures.
Sure, I have creates some codes by myself, but seems its to be not correctly working.
My target is to support [POWER] button on the PB0 pins, which should switch the MCU to HALT mode and wake it up by pressing the button in sequence.
Below is my example of the enter to standby and wake up procedures:
void GoToStandby(void)
//config PB0 pin to accept interrupt to wake up
SetBit(PBDDR,0);
SetBIt(PBOR,0)
//config wake up condition
//by falling edge on SWITCH_POWER pin
//EICR[7:6]=10 for falling edge
//EISR[7:6]=00 for no interrupt on PB0..PB2
//EISR[7:6]=01 for interrupt on PB0
//EISR[7:6]=10 for interrupt on PB1
//EISR[7:6]=11 for interrupt on PB2
//reinit config registers
EICR=0;
EISR=0;
//set IE3 interrupt by the falling edge
SetBit(EICR,7);
ClrBit(EICR,6);
//config wake up of PB0
ClrBit(EISR,7);
SetBit(EISR,6);
//enable interrupt by i/o
EnableInterrupts();
//enter to HALT
Halt();
void EIx_IT_Routine(void)
//disable any interrupts for a while
DisableInterrupts();
//delay for debounce
Wait100ms();
//check if swith on PB0 has been pressed
if (!ValBit(PBDR,0))
//P0 not confirmed - back to HALT
EnableInterrupts();
Halt();
else
//disable interrupt on PB0
ClrBit(PBOR,0);
//restart the program by asm jump
{_asm
(''jp 0xe000'');
Thank you,
Alexander.
