Free ST7 programmer
sjo
Posted on May 11, 2007 at 15:48
Free ST7 programmer
42 REPLIES 42
sjo
Posted on May 28, 2004 at 08:31
Just to keep everybody informed, I have just updated Flash bash to support RCCR calibration byte restoration after a device erase.
sjo
developer1
Posted on August 03, 2004 at 08:00
Help please!!!
Anybody can to send me the programmed ST72F264G2?
nixsa_bernardo
Posted on August 06, 2004 at 09:51
Hello, like I can use the free ST7 programmer in a portable computer without port RS-232. With a converter USB-RS232 doesn't work me.
Thank you
huaer2000
Posted on August 13, 2004 at 06:15
dear sjo,
I have maked one FLASHBASH(use St72C254), but it doesn't work. it failed when I use ''FLASHBASH windows software\program option test''. so I use
ST7MDT1-DVP2 to debug the software and I found the program can
not run to the loaction(label eReceive) of the program(see the followings)
ld A, COMMAND
inc A
ld TX_byte, A
call SCI_Tx ; return command + 1 to pc for cknowledge
eReceive
ret
Is there any wrong. could you give me some idea about this?
Thanks.
mcuinterest
sjo
Posted on August 13, 2004 at 07:11
The hardware and software has been extensivly tested, make sure you are using the latest version of the firmware/windows software.
Also check that the firmware is using the software uart because you are using a 254 - check SOFTUART is defined in main.inc.
If you still have problems recheck connections.
The serial cable should be 1-1, eg. pin1-pin1, pin2-pin2, etc.
sjo
beichler
Posted on August 24, 2004 at 08:24
at first a big compliment to sjo
Now I've a question. I've the ready compiled .s19 file for the microcontroller ST72T774 Now i want to flash the controller with this file. I've read the it will be programmed with JTAG
How is the flashing possible?
Thanks a lot
sjo
Posted on August 24, 2004 at 10:35
Sorry but Flashbash only supports Flash ST7 devices, the device you are uisng is OTP/eprom only.
sjo
beichler
Posted on August 24, 2004 at 11:24
Means OTP One Time Programmable ??? Thats stupid I think.
sjo
Posted on November 11, 2005 at 08:20
Just to keep you all informed updated software/firmware has been released which adds support for new ST7 devices.
sjo
sjo
Posted on April 06, 2006 at 17:50
Another update, fixed a couple of bugs with ultralite programming.
sjo
