Free ST7 programmer
sjo
Posted on May 11, 2007 at 15:48
Free ST7 programmer
42 REPLIES 42
Posted on January 07, 2004 at 06:04
How con I implement a branch table in inline assembly with Metrowerks C compiler? Following code doesn't work :
asm{
LD X,Nerx
SLL X ; X <- Nerx * 2
LD A,(TB_GRAF_RX+1,X)
PUSH A ; MSB of return @
LD A,(TB_GRAF_RX,X)
PUSH A ; LSB of return @
RET
; Branch to subroutine (TB_GRAF_RX + 2*Nerx)
TB_GRAF_RX:
DC graf_rx_0, graf_rx_1, graf_rx_2 ,graf_rx_3
DC graf_rx_4, graf_rx_5, graf_rx_6 ,graf_rx_7
graf_rx_0:
graf_rx_1:
and so on...
VD
sjo
Posted on January 07, 2004 at 07:13
Quote:
On 2004-01-07 06:56, mcuinterest wrote:
dear sjo,
I have problem about ICP: as you know there is no need of isolation
about ICCDATA and ICCCLK pin if these two pin is configured as output(decribed in the data sheet). But if I solder a blank chip on the board and begin to program with ICP and there are two LED connected with these two pin(include two 680ohm series resister. But I found I can not program the chip with ICP mode by using ST7-STICK. what is the problem? can I use FLASHBASH to program?
best regards,
mcuinterest
The problem you are seeing is due to the open-drain communication method used for ICP.
Flashbash should suffer the same fate as it uses the standard ICP protocol - but I have not tested it.
sjo
huaer2000
Posted on January 12, 2004 at 05:33
dear sjo,
I am making a prototype of FLASHBASH, but it is difficult for me to find
the two parts ZVP3306 and ZVN3306 or the direct replacement of the
two MOSFET. coudl you do me a favor to provide the requirements of the two MOSFET(Votage, Current, Rdson etc). I want to find the nearest part to use. Thanks your support.
Best Regards,
Mcuinterest
sjo
Posted on January 12, 2004 at 05:51
Really any kind of small mosfet is ok (parts are Zetex if you require data.
ZVP3306 - also use BSS110
ZVN3306 - also use BS108
sjo
huaer2000
Posted on January 15, 2004 at 07:34
dear sjo,
can I use FLASHBASH to program the board with 3V power supply?
I know St7 Stick can do this?
Best Regards,
Mcuinterest
sjo
Posted on January 15, 2004 at 08:25
Flashbash has been tested down to 3.2v.
sjo
sjo
Posted on January 20, 2004 at 05:40
Added Device Identifier support for ICC mode devices.
ST7FLITES2/S5 bootrom modified, incorrect option byte address used.
ST7265x programming possible with hardware watchdog enabled.
sjo
tlf
Posted on February 03, 2004 at 08:16
But how one can build a FlashBash programmer without having pre-programmed uC? How can I obtain one?
With regards
malfrok
Posted on February 12, 2004 at 13:08
Hello every body!
I have realized 4 FLASHBASH programers.
I can't have M25P10 memory, because ST doesn't manufacture them any more. I have M25P10-A. It doesn't work good!! I have a lot of problem to access the memory in PC mode or keyfob mode!!
Is there anybody to help me?
Thanks a lot,
Malfrok.
sjo
Posted on February 12, 2004 at 13:33
Could you explain your problem in a bit more detail, either M25P10 or M25P10A work with no problems in Flashbash.
sjo
