I need a cascaded timer
rbennett2
Posted on May 11, 2007 at 13:21
rbennett2
Posted on May 09, 2007 at 18:42
I'm running an STR750F with the 75x library and want to set up Timer 0 and Timer 1 to be a cascaded countdown timer, with an interrupt occurring every time Timer 1 runs out. Can anyone supply me with a simple piece of code that does that? I've gotten a cascaded timer running but it won't generate an interrupt.
Thanks!
rbennett2
Posted on May 10, 2007 at 14:31
I found the problem. No reply needed.
javidaboo
Could you please indicate what the solution was.
