Flash Update only?
dk5ug
Posted on January 16, 2003 at 17:31
Flash Update only?
3 REPLIES 3
dk5ug
Posted on May 17, 2011 at 11:53
Using the PSDsoft Express (v7.70) it looks as if the PLD is reconfigured
with every Flash update also. On the other hand I understand, PLD can
be reprogramed less often than Flash memory.
Is there a way to keep the PLD unchanged while updating Flash memory
only?
dk5ug
Thank you!
It works.
I feel better now.
yu-jun
In Express software, when you do the last operatin: JATG/ISP, you can select Flash in 'PSD region ' part of step2 in dialogbox of JATG/ISP Operation. So that you can undate the Flash memory and keep other.
