FLASH st7c2334j4
chill_just_chill
Posted on April 14, 2003 at 06:51
FLASH st7c2334j4
15 REPLIES 15
chill_just_chill
Posted on April 10, 2003 at 15:10
Actually, I need to write a program that tests the FLASH of the st7c2334.
I need to program al the memory bytes to '0' and than check.
I need to program al the memory bytes to '1' and than check.
If the checks correspond, the flash is ok.
Has anyone got an idea how to do that ?
tia
Chr
sjo
Posted on April 11, 2003 at 09:40
Because you are using a CFlash part you will need an external micro to put the device into programming mode (IAP is not available on this device) and just upload a custom bootrom.
You could adapt my prgrammmer to do this. (www.spen-soft.co.uk)
Or if ST would document the 'RAM Exec' function of Visual Programmer you might be able to do it from there, but you would still need a means of uploading the custom bootrom.
Spen
chill_just_chill
Posted on April 11, 2003 at 16:01
indeed,
that's just what I'm doing:
downloading code into RAM of st7 via ISP through another st7.
It's my thesis.
sjo
Posted on April 11, 2003 at 17:45
Why don't you just copy my programmer - www.spen-soft.co.uk
You could remove the flash and a few components and have a small pcb.
All the source and info is there
Spen
chill_just_chill
Posted on April 11, 2003 at 23:48
I CAN program the flash of an st7, I have a much simpeler programmer than yours..
But I need a program that writes to flash from RAM
greetz
sjo
If you can write to the flash then you must already have a bootrom which executes from RAM - I'm afraid I don't understand what you want.
SJO
