FLASH BANK Start address
m_j_butcher
Posted on February 23, 2007 at 12:17
3 REPLIES 3
m_j_butcher
Posted on May 17, 2011 at 09:35
Original message again:
Hi All
It is possible to define the FLASH block start address using FMI_NBBADR / FMI_BBADR.
I program the FLASH (512k size) to start at 0x80000 (ends at 0xfffff) and then program some code at 0x90000.
Now I reprogram the FLASH to start at 0x70000. I expected that I could shift the data programmed at 0x90000 to 0x80000 but this doesn't seem to be the case. The data stays at 0x90000.
What changes is that the FLASH now occupies the range 0x70000..0xeffff
Therefore I conclude that it is not the FLASH access address which is being changed but instead an access windows which is being changed.
Can anyone confirm this???
Mark Butcher
www.uTasker.com
m_j_butcher
Sorry - Posts seems to be failing due to a data base error(?)
jgoril
...your 512k Flash bank can be placed with 512k boundary, i.e. at 0x000000, 0x080000, 0x100000 etc...
