Firmware upgrade : USB + DFUSE. How ??
amoreno
Posted on June 19, 2008 at 10:04
amoreno
I trying to implement a USB application on my STR711 for download new firmware from DFUSE application.
I downloaded the USB firmware library from ST (um0290.zip)
I use IAR Workbench 5.11 and if I compile the project, it returns me several errors on INIT_TAB.s file
Bad instruction COMMON INTVEC:ROOT
Bad instruction COMMON INTVEC_ROM:ROOT
Invalid Syntax DCD sfe(INTVEC_ROM) - sfb(INTVEC_ROM)
Invalid Syntax DCD sfb(INTVEC)
Invalid Syntax DCD sfb(INTVEC_ROM)
I have never used this file before. What is the purpose of it? What is wrong?
What I have to change to compile correctly?
Thank you for you help, I appreciate very much
ALFA
