2007-06-11 02:11 AM
2011-05-17 12:44 AM
I’ve struggled a bit with the FFT from the DSPLIB.
To me it looks like it’s not working correctly. I’ve tested the algorithm with the test done in the doc. 4.2 (table 4) The result is a bit strange. When I use a sine wave the imag-part is correct if you take the complex-conjugate but the real-part is zero. When I use a co-sine wave the real-part is correct but not the imag-part. Has someone got the FFT up and running correctly?
