External clock DVP3 generates GDI Error
henrik239955
Posted on June 16, 2005 at 08:28
henrik239955
Posted on June 14, 2005 at 06:36
Hi, I'm using STMDT10-DVP3 and STVD7 3.1.1 to emulate ST7LITE29. When I select FOSC: EXTERNAL the following message appears on screen: ''GDI Error: [10255]''. I have an external 8MHz qrystal connected to OSC1 and OSC2. Whats wrong?
bood
olivier239955
Posted on June 15, 2005 at 06:52
When you want to use an external clock you must connect TTL clock signal between EXTCLK pin and GND (see figure 8 of ST7DVP3 user manual attached). The development kit doesn't use the application Crystal connected on OSC1/OSC2 because flat rebbon capacitors can disturb oscillator.
But if you want to use 8MHz frequency you can select it directly with menu: Debug instrument > MCU configuration > Option and chose 8MHz.
With best regards,
________________
Attachments :
st7dvp3.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I05s&d=%2Fa%2F0X0000000bWD%2FBZ.4JuJ3L1z1BuhX8NtFLHTAT.ImWrtvyGF9G5bp9EM&asPdf=false
henrik239955
Okey, thanks!
/bood
