2009-07-09 02:21 AM
2009-04-30 11:48 AM
I installed ST toolset new program in windows 2000.
When I tried to open the st visual programmer, I recieved a message window saying ''Cannot load JICC_API Dll'' even before vis. programmer window appears. And Then brings up the configuration setting. I choose my micro and say OK, but it brings up another window saying ''choose a valid configuration''. Need your help. Thanks sanjaya ________________ Attachments : 1.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0GG&d=%2Fa%2F0X0000000bWG%2F4uFRfIeyTmv2Fhi8VOfQlrXN6RHn3UOyqtFkgqLjqv4&asPdf=false2009-05-05 03:32 AM
Hi Sanjaya,
Exactly the same happens to me - with win2000 and the new ST toolset (pack17). Because I'm only using the programming mode (STVP), I've re-installed the STtoolset-pack15 as workaround and all the features work fine. Nevertheless, I'm curious when STM will fix this bug... Regards, WoRo2009-05-06 11:23 AM
Thanks a lot for the info.
Can you help sending me the link for stttoolset pack 15. Thanks in advance. sanjaya2009-05-07 02:40 AM
Hi Sanjaya,
there are no known links to older versions. I tried to upload the whole file and to append it here, but I failed. :-( Most probably it is the best way you ask your local distributor. Nevertheless I think you would really promote this forum when you make our highly devoteded moderators discharge their duties ... Greetings, WoRo2009-05-07 03:21 AM
...succeeded in packing the file to a .zip file and attaching it here.
You only have to extract the enclosed file. :-) Regards, WoRo ________________ Attachments : st7toolset_Pack15.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzne&d=%2Fa%2F0X0000000bWH%2FOxuivRD88T_5Rnw4fnKGOFph5wW6lSxa8Oodkps5oBY&asPdf=false2009-07-09 02:21 AM
Hi to all Users (as well as to the Moderators :-o)
I became aware of that my attachement from 2009-05-07 could not work because the file has been corrupted - sorry. I'll try again to attach a .zip file of pack Hope it works now. BTW: Even in sttoolset Pack 18 the experts of STM did not fix the bug... WoRo ________________ Attachments : st7toolset_pack15.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0G6&d=%2Fa%2F0X0000000bWF%2FEF28PEedOH1DQ4NCBEYxy.I5lfpXJa6NYxG05v8ImGU&asPdf=false
