2008-09-17 05:24 PM
2008-05-29 01:28 AM
I'm working on st10f168 with st10flasher, now, load monitor is ok, dump is ok, but i'm not able to program flash because appears error messagea boute flash erase: EraseFlash failed.flash
How can i erase ?2008-06-01 10:05 PM
Hello Newsamo,
Programming voltage (12V) of the on-chip Flash memory must be supplied to pin VPP(pin 84). Is the 12V ensured in this pin during programming/erasing operation? Best regards, Najoua.2008-09-17 05:24 PM
Hello Najoua,
in which others microcontrollers of st10fxxx family I need to apply the voltage programming to erase and program? Thank you !!!
