ERASE FLASH
newsamo
Posted on September 18, 2008 at 02:24
ERASE FLASH
3 REPLIES 3
newsamo
Posted on May 29, 2008 at 10:28
I'm working on st10f168 with st10flasher, now, load monitor is ok, dump is ok, but i'm not able to program flash because appears error messagea boute flash erase: EraseFlash failed.flash
How can i erase ?
najoua
Posted on June 02, 2008 at 07:05
Hello Newsamo,
Programming voltage (12V) of the on-chip Flash memory must be supplied to pin VPP(pin 84).
Is the 12V ensured in this pin during programming/erasing operation?
Best regards,
Najoua.
joluci
Hello Najoua,
in which others microcontrollers of st10fxxx family I need to apply the voltage programming to erase and program?
Thank you !!!
