2008-02-25 07:41 PM
Difference between FW and FAW chips
2011-05-17 12:50 AM
Hi friends, I was using an ARM9 STR912FW44 in my projects.
Last week i was projecting another system and i was searching ST Microelectronics website for the STR912FW44 datasheet. Surprisingly i found that there is another STR912, but this time it has FAW44 on the chip spec. What this FAW means ? I downloaded both datasheets and i found no difference between them. Thanks for the attention DocHell2011-05-17 12:50 AM
The STR91xFxxxxx are the first samples with silicon revision B and D and the STR91xFAxxxxx are the last samples(production devices) with silicon revision G and H.
Refer to STR91xFA errata sheet for more information:http://www.st.com/mcu/modules.php?name=mcu&file=familiesdocs&FAM=101#Errata Sheet
