Data Compression algoritms
sisto
Posted on September 02, 2003 at 05:57
5 REPLIES 5
sisto
Posted on August 28, 2003 at 11:14
HI there,
has anyone developed encode/decode algoritms to compress/expand ASCII strings and/or graphic data bytes to reduce flash look-up tables dimensions ?
I'm working around a project which use a 64x128 graphic LCD, so You can understand the problem.
sixtus
coor
Posted on September 01, 2003 at 06:00
LZH.
sisto
Posted on September 01, 2003 at 06:28
Hi coordinator,
beautiful, concise, extremely clear answer, I appreciate the attention, but it was not that my question !
Evidently you don't have used Your ''lateral mind''.
My direct question is : is there anybody which could provide me the ''C'' or assembler sources ?
Thanks for Your attention.
sjo
Posted on September 01, 2003 at 08:48
probably the simplest to implement in a 8bit micro is RLE compression.
There are numerous C examples on the net which could be easilt adapted to the ST7.
Hope this helps
SJO
sisto
Yes SJO, thanks.
Waiting to any answer from the forum people, I have already implemented an RLE encode/decode algorithm.
Respecting a B/W image of 1024 bytes ( LCD 64x128 ), I have gained a compression of about 42%.
As regards the of Shannon entropic limit, I am fairly satisfied.
Sixtus
[ Questo Messaggio è stato Modificato da: sixtus il 02-09-2003 09:29 ]
