2014-05-15 02:18 AM
We need to modify one of our existing company products to be able to be controller by external I/O. The only externally available I/O-signals are the 6 JTAG pins. These JTAG pins are connected to the PLD I/O-Port C. I would like to control pins PC3 and PC4. But somehow I do not managed to get them active. These next items are applied: - set PC3 and PC4 to GP I/O mode in PSDsoft Express - set the CSIOP to address 0x7F00 in PSDsoft Express (last 256 Bytes of the 32KiB SRAM) - set the PC3/PC4 data direction registers (at address 0x7F14) to '1' (output) - toggle PC3/PC4 output registers (at address 0x7F12) But nothing happens on the outputs. Testing them as inputs also shows no results. Maybe I forgot some setting in the PSD part of the uC? thanks, Henk
