Clear CMOS on Atlas Eval Boards
stephen239955_st
Posted on November 19, 2002 at 13:38
4 REPLIES 4
stephen239955_st
Posted on November 14, 2002 at 12:15
How can I clear the CMOS of the STPC Evaluation board?
thierry239955_st
Posted on November 19, 2002 at 06:32
There is a jumper somewhere on board. To be sure the clear is done correctly, I think you also have to disconnect the power supply when you play with this jumper.
Farfalla
stephen239955_st
Posted on November 19, 2002 at 12:41
Farfalla;
This does not appear to work on the AtlasISABD? Is there something else I need to do?
fabrice
Posted on November 19, 2002 at 13:20
Stephen,
you need to follow the following steps:
- power off the board
- close the jumper
- power on the board
- check that the postcode 0D is reached
- open the jumper
It should be OK now !
Fab
