CAN PROBLEMS
robosoft
Posted on October 08, 2008 at 08:08
CAN PROBLEMS
4 REPLIES 4
robosoft
Posted on May 17, 2011 at 09:56
I have a microntoller (PIC) sending every 100mS a 8 bytes long message.
On STR912 side, I have defined a msgobject to receive this message.
The message I receive is sometimes (1 on 1000) corrupted.
It is always the same byte has the same incorrect bit.
Bitrate is on both sides 500K and is correct. I changed bitrate to 100KB with no result.
I am sure that the message on the CANbus itself is correct. I capture the CAN message with a PC with CAN card.
To receive message I use the CAN_Receivemessage() function of the ST-library (no interrupt is used).
Any idea what I could try ?
Is it necessary to call CAN_Releaseobject each time I call CAN_Receivemessage() ?
Luc
robosoft
I decreased the PCLK to 48MHz. Problem seems to be solved...
Another item in the errata list ?
jonathan2
Check out the datasheet. It clearly states the maximum frequency of PCLK is 48MHz in the electrical specifications section.
I know there's missing parts and ambiguities, but you should familiarise yourself with what is there.
robosoft
shame on me !
