Arm or Thumb C Code?
psantofe
Posted on April 10, 2009 at 09:30
3 REPLIES 3
psantofe
Posted on April 09, 2009 at 11:15
I'm working on a STR730-ks eval board by IAR SYSTEMS. IAR Embedded Workbench IDE rel. 5.30.2.
I'm using the example made by IAR.
My question is: all examples that use interrupts work setting ARM C Code mode only (never in Thumb).
Which is the reason of this?
Is it possible to set Thumb C Code instead of ARM in application where interrupt are used)?
How? Where do I must set instructions in order to do this?
Paolo
sjo
Posted on April 09, 2009 at 15:10
arm7/9 always enter isr's in arm mode.
you can switch to thumb mode once you are in the handler.
This is why many people use asm to wrap a 'c' interrupt handler.
Cheers
sjo
psantofe
Thank you sjo!
I found solution to my problem enabling ''Generate interwork code'' inside project options of IDE in C/C++ Compiler section. This allows me to mix my Thumb code with Arm Interrupt service routine.
Cheers
Paolo
