active high chip select grrrr
fischer
Posted on August 17, 2004 at 08:16
fischer
Posted on May 17, 2011 at 12:02
hallo,
my active high chip select on porta is much longer than the data is valid
that i write to an lcd. ???!!!!
in psdexpress i select active high chip select for PA7
// PSD settings
// aaaaaaaaaaa
Bporta_dir=0x8D; // input=0
Bporta_data_out=0x7F;
Bporta_oe=0x81;
whats wrong?
fischer
thats it, i already found it.
i do not do so using other active low cs, there is no such problem ??!!
i do not use the _wr or _rd signals to gate the 2 other active low cs i use.
-strange-
why?
thanks !!!!!!!!!!!!!!!!!!
