Which are the motionFX libraries that support Cortex-M0/BlueNRG-2 core?
pradeesh
There are a lot of motion libraries in X-CUBE MEMS-1. If I need to integrate a ****-meter, free-fall, intensity detection, tilt detection codes with BlueNRG-2 (Cortex-M0) along with Bluetooth stack, is that possible?
niccolò
Hi @pradeesh​ ,
yes, it is possible to run the motionFX library on cortex-M0, along with BlueNRG-2 library to support bluetooth.
Niccolò
p.s. if you found a solution to your problem, please, select a best answer to help other users with similar issues
Eleon BORLINI
Hi @pradeesh​ ,
do you have any feedback from your side?
-Eleon
