What is the maximum range of SPI communication protocol ?
‎2021-03-21 11:32 AM
I want to use accelerometer using stm32f4 mcu with SPI protocol.
The range is between 1 and 2 meters. Is this work good ?
Thanks...
- Labels:
Accelerometers
SPI
STM32F4 Series
‎2021-03-21 5:08 PM
SPI over 2 meters? No way, without extender
-- pa
‎2021-03-21 9:16 PM
Technically you may do that but it will not be a trivial task.
The maximum possible length of SPI line at a specific clock frequency is limited by the phase delay between CLK and MISO seen by the master.
Line driver may be required. Typical issues of a long transmission need to be taken care: impedance matching, inductive noise, etc.
‎2021-03-22 1:59 AM
As mentioned, for high speed, you would need impedance-matched lines and transceivers.
However, most accelerometers have a relatively low bandwidth, I guess 1ksps or less would do for your purpose.
You can reduce the SPI clock frequency, to ease the line requirement.
About 100 ... 200kHz should suffice.
