We are using H3LIS100DL MEMS Accelerometer Sensor with STM32L496XX Board. We are using I2C connection for getting the x,y and z axis data.We are getting the Device ID correct but not able to get the Correct x,y and Z axis data.Please give anyideas.
ORana.1
5 REPLIES 5
Eleon BORLINI
Hi @ORana.1​ ,
can you please share the LSB you are getting?
Are you correctly configuring the H3LIS100DL device?
See for example the C drivers on Github --> h3lis100dl_read_data_polling.c
-Eleon
ORana.1
Hello @Eleon BORLINI​
I am setting below configuration
CTRL_REG1 = 0x27
CTRL_REG2 = 0x00
CTRL_REG3 = 0x00
Please check
When i am reading the STATUS_REG its always give the value 0x99
ORana.1
If anyone is having some logic or correction for this Problem Just help me.
i have used the same example as you mentioning but still we are not getting the correct result.
Please guide us if we are missing some thing.
