We are using H3LIS100DL MEMS Accelerometer Sensor with STM32L496XX Board.
We are using I2C connection for getting the x,y and z axis data.We are getting the Device ID correct but not able to get the Correct x,y and Z axis data.Please give anyideas.
2022-04-08 4:49 AM
2022-04-08 4:53 AM
Hi @ORana.1 ,
can you please share the LSB you are getting?
Are you correctly configuring the H3LIS100DL device?
See for example the C drivers on Github --> h3lis100dl_read_data_polling.c
-Eleon
2022-04-08 5:47 AM
Hello @Eleon BORLINI
I am setting below configuration
CTRL_REG1 = 0x27
CTRL_REG2 = 0x00
CTRL_REG3 = 0x00
Please check
2022-04-08 5:48 AM
When i am reading the STATUS_REG its always give the value 0x99
2022-04-12 4:33 AM
If anyone is having some logic or correction for this Problem Just help me.
2022-04-17 10:32 PM
i have used the same example as you mentioning but still we are not getting the correct result.
Please guide us if we are missing some thing.
