wayne23
Visitor II
June 13, 2016
VL53L0X Register Map?
  • June 13, 2016
  • 16 replies
  • 12418 views
Posted on June 13, 2016 at 21:32
Having previously used with the VL6180X, I expected the VL53L0X to be similar in architecture.  However, while I found a somewhat useful data sheet, it does not seem to contain a register map.  It seems I'm supposed to use the example source code to understand how to program the VL53L0X.  However, I find the example code to be written in a way I'd almost call obfuscated because of the dense use of &sharpdefines to recursively redefine things.  It's taken me nearly 2 hours to unravel and understand just the VL53L0X_DataInit() function.  Is there a register-level description of the VL53L0X available?  If so, I can't find it.
Wayne
#vl53l0x
Tvan .13
Crosstalk is probably an issue in my design. Currently I'm checking the MIKROBUS implementation and build on from there. Thanks
