2020-02-20 08:18 AM
Hello, we're using A3G4250D in our project, and get data from it successfully in the stream mode, but, it accured, that from time to time there are random steps in the output data, and we have no clue on what can cause them. Did anyone meet such issue, can you help with the solution, please, if there is one.
The schematic and output graph are attached to visualize the problem
2020-02-21 07:01 AM
Hi @RZhar.1 , the jump behavior is common to the there axis, so I believe it is not a mechanical-related issue. I believe it's an electrical / digital effect so here some questions to delimit the problem:
5. Can you try if you get the same issue in Bypass mode?
