2022-07-10 06:20 PM
We are currently evaluating STEVAL-MKI160V1 with STEVAL-MKI109V3.
There is a Bluetooth module connection in the schematics of STEVAL-MKI109V3. Are there any documentations about that Bluetooth support? Can it be used to wirelessly stream out the sensor data to a PC?
Our test setup involves a moving machinery and for safety reasons, we need to be at a distance from it.
Are there available options for wireless transmission of data from the eval board?
2022-07-13 06:13 AM
Hi @NPo.1 ,
there was indeed the STEVAL-MKI115V1, but it is obsolete and is no more supported by ST.
You might use another approach, such as the pack Nucleo board+IKS01A3+Bluetooth, but not the STEVAL MKI109V3.
-Eleon
2022-07-13 06:13 AM
Hi @NPo.1 ,
-Eleon
2022-07-13 04:19 PM
Thanks @Eleon BORLINI!
