2024-08-14 1:59 PM
I'm using STEVAL-MKI109V3 and STEVAL-MKI193V1 (ASM330LHH IMU). Using the Unico GUI, I see that the IMU is detected and recognized however I don't manage to stream any data from the IMU. I enable the accelerometer and the gyroscope and set the sample rate, however no data is printed to the log file and to the GUI plot - GUI plot displays curves which are steady and zero and are non responsive.
Any suggestion on how to solve this issue?
Thank you very much!
2024-08-29 4:45 AM
Hi @MEMSRunner ,
That sounds strange. Can you share with me your writings and also some screenshots of Unico GUI?
Just to understand better your problem. Thanks!
