2024-12-06 10:35 AM
We embed LIS3MDLTR on our board that we produce, because this has high sensitivity: 6842 LSB/gauss. This corresponds to 0.146 mgauss/LSB, if I convert correctly. The other products has significanltly lower sensitivity: 1.5 mgauss/LSB. What are you proposing to replace the LIS3MDLTR once it is discontinued?
https://www.mouser.com/PCN/STMicroelectronics_15054_1.pdf
2024-12-09 12:12 AM
Apart from the possibility of obtaining remaining quantities of the LIS3MDL from distributors, the magnetometer IIS2MDC and LIS2MDL are still available, but they do not achieve the fine resolution and therefore the sensitivity of the LIS3MDL. In this respect, STMicroelectronics is unfortunately unable to offer a fully-fledged or better successor.
/Peter
2024-12-06 10:45 AM
You could always inventory a shed-load for your own use, there look to be plenty in the channel today.
2024-12-09 12:12 AM
/Peter
