Sensor Fusion output parameters.
‎2021-10-07 11:28 PM
Could you recomend me a document that speaks about the format of the matrix parameters obtained trought sensor fusion? For example: linear_acel, quaternion...
Best regards.
- Labels:
Developers Corner
‎2021-10-08 5:40 AM
Hi @RBAGU.1​ ,
are you referring to the MotionFX library of the X-CUBE-MEMS1 FW function pack?
If so, please have a look to the User manual UM2220: MotionFX library, where the various functions called in the library are described.
Let me please know if this can help you.
-Eleon
‎2021-10-08 5:40 AM
Hi @RBAGU.1​ ,
-Eleon
‎2021-10-08 5:51 AM
Many thanks. Best regards.
