2016-06-23 2:53 PM
I have read over the user manual for the MEMs board, and I am using the example code from the DataLogFusion. However, I can never get the osx_MotionFX_compass_isCalibrated function to return true. I have tried hitting the reset button, moving the board clockwise in all three axis, moving it in a figure 8 and lots of different combinations.
Anyone have an idea how to do this successfully or what may be the problem? Thanks!2016-07-01 7:14 AM
I don’t know which HW you are using, but try to check if all axes of all sensors (mainly ACC and MAG) are in the same direction. If not do the correction in your code.
Best Regards,
Marian
