2019-03-29 05:40 AM
Hi
I have to build a density Sensor for a beer brewer. I want to do it with a differential pressure method. I need a pressure sensor for that. So I found the pressure sensor LPS33HW. Does someone know if the material of this sensor is bio compatible? So that when i put it in beer that the beer isn't contaminated.
2019-03-29 05:57 AM
As you are waiting an answer, explore the alternative way if parylene coating the whole board and recalibrate the sensor. Parylene coating is well mature process for biocompatibility if electronic boards.
2019-03-29 06:06 AM
Www.parylene.com as example
