Nucleo-L053R8 with SHT15 humidity& temp sensor.
gandhi
Posted on May 21, 2015 at 16:09
I'm using SHT15 to measure temp&humidity. Here,I connected
I2C1_SCL  in PB6.
I2C1_SDA in PB7.
I attached the SHT drivers i created. Unfortunately, I couldn't see the values on serial communication. Could some one look into my code and help me out.
1 REPLY 1
Nickname3482_O
Posted on May 28, 2015 at 15:41
SHT15 is not an ST sensor and we do not support competitor's devices.
Our humidity sensors are HTS221 and HTS221E and we would be glad to
support you if you select one of them.
Best Regards,
Adalberto
