Not able to get acceleration data from Adafruit LSM6DSO32 with STM32 Nucleo F446RE
atamby187
I have been trying to get acceleration data from an Adafruit LSM6DSO32 with the STM32 Nucleo board F446RE via i2c. I used the STMems_Standard_C_drivers  (GitHub - STMicroelectronics/lsm6dso32-pid at 308cf0e4de0db190c453f3e211b0c40990f1f39b) in order to set the IMU properly. I also use the STM32CubeIDE app to programme the MCU.
Despite many efforts, the Nucleo board is not able to recognise the IMU (I checked that a test buffer that prints whether the device is recognised using the whoami register (please refer to the 7z folder attached)), though I double checked the slave address of the components and the connections (please see attached image (IMG_0605.jpg). Could you please help me solve that problem?
You can find enclosed a copy of the STM32CubeIDE project.
Best regards,
Audric
Federica Bossi
Hi @atamby187 ,
Welcome to ST Community!
I see two possible issues in your code:
  1. the who_am_i is defined as LSM6DSO32_ID in the drivers while you use another value
  2. Since you have not connected pin D0 you can try the i2c address LSM6DSO32_I2C_ADD_L
4 REPLIES 4
Federica Bossi
Hi @atamby187 ,
Hi Frederica Bossi,
Thank you for helping solve this problem.
The problem was with the i2c address of the Adafuit IMU which is 0xD4 (0x6A << 1) and not 0x6A as seen on Adafruit website.
Best regards,
Audric
An I2C address is just 7 bits, so Adafruit are correct to say that the I2C address is 0x6A = 110 1010
The value 0xD4 is made up of the address plus the R/W bit1101 010= 0xD4
This is a frequent cause of confusion:
https://www.avrfreaks.net/s/topic/a5C3l000000UXMPEA4/t142031?comment=P-1150738#:~:text=The%20discrepancy%20between%20talking%20of%20I2C%20addresses%20as%207%20or%208%20bits%20is%20very%20common%20indeed%20in%20software%2C%20tutorials%2C%20articles%2C%20and%20device%20datasheets.
As shown in the ST datasheet, the value 0xD4 is the "SAD+R/W" - ie, Slave ADdress plus the R/W bit:
Hi Andrew,
Thank you for the clarification. I am quite new in electronics.
Best regards,
Audric.
