MotionFX hard fault
‎2018-02-27 10:26 PM
I'm trying to implement MotionFX in my application. So far I have a very basic setup which executes correctly.
MotionFX_initialize();
MotionFX_GetLibVersion(ver);
printu(ver, 1);
MotionFX_getKnobs(&iKnobs);
iKnobs.output_type = MFX_ENGINE_OUTPUT_ENU;
iKnobs.LMode = 1;
iKnobs.modx = 1;
MotionFX_setKnobs(&iKnobs);
MotionFX_enable_6X(MFX_ENGINE_DISABLE);
MotionFX_enable_9X(MFX_ENGINE_ENABLE);�?�?�?�?�?�?�?�?�?�?
Then, in a thread, I pull data out of my sensors and push it to the motionfx:
MFX_input_t data_in;
MFX_output_t data_out;
data_in.acc[0] = mptr->acc.AXIS_X * FROM_MG_TO_G;
data_in.acc[1] = mptr->acc.AXIS_Y * FROM_MG_TO_G;
data_in.acc[2] = mptr->acc.AXIS_Z * FROM_MG_TO_G;
data_in.gyro[0] = mptr->gyro.AXIS_X * FROM_MDPS_TO_DPS;
data_in.gyro[1] = mptr->gyro.AXIS_Y * FROM_MDPS_TO_DPS;
data_in.gyro[2] = mptr->gyro.AXIS_Z * FROM_MDPS_TO_DPS;
data_in.mag[0] = mptr->mag.AXIS_X * FROM_MGAUSS_TO_UT50;
data_in.mag[1] = mptr->mag.AXIS_Y * FROM_MGAUSS_TO_UT50;
data_in.mag[2] = mptr->mag.AXIS_Z * FROM_MGAUSS_TO_UT50;
MotionFX_propagate(&data_out, &data_in, 0.01);
MotionFX_update(&data_out, &data_in, 0.01, NULL);�?�?�?�?�?�?�?�?�?�?�?�?�?
For now, the 0.01 deltatime variable is not accurate, but will becorrected later.
The problem is that I can not call the _propagate and _update function. If I leave only _propagate, I can call that function ripediatelly and get some results. Same with _update. However, if I call them both with each iteration, I run into a hard fault every time.
I have increased stack size to 0x6000 in .ld file with the same results.
In my debugging, it seems that the two functions run fine outside of the thread context.
‎2019-01-06 4:01 AM
I think you configured the stack size to small.
‎2019-01-07 11:32 PM
I was tried to increase the stack but it does the same.
‎2019-01-08 12:51 AM
What stack size did you try?
‎2019-01-08 12:52 AM
_Min_Stack_Size = 0x1000; /* required amount of stack */
‎2019-01-09 1:29 AM
I would try to increase it even more e.g. 0x2000.
‎2019-01-11 12:17 AM
I tried with 0x2000 and 0x3000 and it do the same...
But, I think, It's not the problem, The code is the same for the RB and, with than microcontroller works fine!
PD. Sorry for the delay
‎2019-01-11 7:02 AM
It is really strange, there must be something wrong it your project. There is not reason why it should not work on the MCU with more memory.
‎2019-01-13 11:45 PM
yes! I think so.
I made the projects with STM32CubeMX and I didn't change the configuration.
I can't understand...
‎2020-11-05 10:07 PM
i meet the similar problem..
I have enable CRC and enlarge _Min_Stack_Size = 0x8000, but no help...
- « Previous
- 1
- 2
- Next »
