2020-07-27 08:41 AM
I accidentally connected 3.3v to the mki173v1 - could I damage it?
2020-07-27 10:42 AM
As you can find in the datasheet of the LSM303AH the maximum supply voltage is 2.2V:
Stresses above those listed as “absolute maximum ratings�? may cause permanent damage to the device.
Nobody will guarantee the specifications anymore if any device has been stressed outside its limits. You should consider the STEVAL-MKI173V1 as damaged.
I'm so sorry!
/Peter
2020-07-27 10:42 AM
I'm so sorry!
/Peter
