2025-02-03 02:35 AM - last edited on 2025-02-07 06:36 AM by Andrew Neil
Hello community ,
I am going to do 9 axis sensor fusion (6axis accel and gyro + 3axis magnetometer) and got across to the MEMs-Studio suite. I've bought STEVAL-MKI109D for motherboard and STEVAL-MKI217V1 as the shield. STEVAL-MKI109V3 is out of stock at that time.
I pluged the USB for STEVAL-MKI109D with mounted STEVAL-MKI217V1, but the STEVAL-MKI217V1 isn't recognised but was recognised as STEVAL-MKI197V1 instead. The features of 6axis are fine but I need to test the 3axis mag also.
Here are my software setting.
STEVAL-MKI109D firmware was updated to v 0.8.14
MEMs Studio 1.4.2
2025-02-07 06:14 AM
Hi @Zefie ,
Thank you for bringing this to our attention. I confirm that we have replicated the issue and it will be fixed in the next release.
We are sorry, we will notify you as soon as the fix is released.
Thank you for your patience!
2025-02-07 06:14 AM
Hi @Zefie ,
