2024-07-03 06:45 AM
I am using MEMS studio version 1.3. If I use an arbitrary timer when debugging the FSM, then according to the specification the timer value should change with each new incoming data sample. But will the value change after three or four samples? Does anyone have a similar problem? Is the error only during debugging?
