2023-03-22 1:23 AM
Hi, in my application I will not use INT2 pin. Is it okay to connect INT2 pin to the GND?
2023-03-27 12:12 AM
Hi @Eleon BORLINI
According to this application note, INT2 default is output forced to the ground
so Is it okay ?
2023-03-24 7:25 AM
Hi @Egemen ,
yes you can, INT2 is by default in high impedance state.
-Eleon
2023-03-27 12:12 AM
Hi @Eleon BORLINI
so Is it okay ?
2023-03-28 6:58 AM
Hi @Egemen ,
you are right, in my mind I was thinking that could be left unconnected, and I wrote high impedance.
It is ok as well.
-Eleon
