2017-04-19 05:25 AM
Hi all,
I'm trying to interface a LSM303AGR, to get the magnetometer and accelerometer values in I2C.
The component is responding well to whoami requests (both compass and magnetometer parts), I manage to get mag values but the accelerometer values seems to be stuck.
Here are my init parameters:
REBOOT
ACCELEROMETER
MEMORY
CONTENT
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG5_A
0x80
RTC_wait_ms
6
REBOOT
MAGNETOMETER
MEMORY
CONTENT
I2C_Write_reg
I2C2
I2C_LSM3_MAG_ADRESS
1
I2C_LSM3_CFG_REG_A_M
0x40
RTC_wait_ms
6
void
I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_WHO_AM_I_ACC
whoamiacc
1
if
whoamiacc
0x33
FAIL(
'LSM303AGR
accelerometer
side
isn't
responding'
else
ACCELEROMETER
INITIALIZATIONS
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG1_A
0x57
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG2_A
0x00
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG3_A
0x00
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
I2C_LSM3_CTRL_REG4_A
0x98
//BDU
ON
+/-4G
Range
and
High
res
ON
I2C_Write_reg
I2C2
I2C_LSM3_ACC_ADRESS
1
0x00
void
I2C_Read
I2C2
I2C_LSM3_MAG_ADRESS
1
0
I2C_LSM3_WHO_AM_I_MAG
whoamimag
1
if
whoamimag
0x40
FAIL(
'LSM303AGR
magnetometer
side
isn't
responding'
else
MAGNETOMETER
INITIALIZATIONS
I2C_Write_reg
I2C2
I2C_LSM3_MAG_ADRESS
1
0x8C
I2C_Write_reg(I2C2,I2C_LSM3_MAG_ADRESS
1,I2C_LSM3_CFG_REG_B_M,0x02);
My reading fonction for the accelerometer is the following:
uint8_t
drdy
0
uint8_t
x_accel
2
0
uint8_t
y_accel
2
0
uint8_t
z_accel
2
0
I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_STATUS_REG_A
drdy
1
if
drdy
0x01
0x01
I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_OUT_Y_L_A
y_accel
2
if
drdy
0x02
0x02
) I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_OUT_Z_L_A
z_accel
2
if
drdy
0x04
0x04
I2C_Read
I2C2
I2C_LSM3_ACC_ADRESS
1
0
I2C_LSM3_OUT_X_L_A
x_accel
2
I get the exact same answer at every reading:
x_accel
0
= 0xA0
x_accel
1
= 0xA0
y_accel
0
= 0xC0
y_accel
1
= 0xC0
z_accel
0
= 0x40
z_accel
1
= 0x40
Am I doing something wrong in the initializations? I would like the accelerometer to be in +/-4G range, 100Hz, without FIFO and in High res mode.
The I2C_Read function seems to work well, my function reading the magnetometer works fine.
Thank you!
2017-04-19 12:25 PM
I think, the address of output registers is not automaticaly incremented, when you are reading multiple bytes. So you are reading only the low byte and due to enabled BDU, the data are not updated. Please check chapter 6.1.1 in datasheet.
If the MSb of the
register address
is ‘1’, the register address is automatically increased to allow multiple data read/writes.You can also check only the ZYXDA bit in status register a then read data for all axis in one multiple read, read 6bytes starting from OUT_X_L_A (28h).
2017-04-20 01:03 AM
I think if the High and Low bytes are the same, then you are reading the same register.
Can you please set the MSB bit of registers address to one, so I2C_LSM3_OUT_X_L_A = 0xA8, I2C_LSM3_OUT_Y_L_A = 0xAA, I2C_LSM3_OUT_Y_L_A = 0xAC to be sure the address will be incremented.
Another option how to confirm my theory is disable BDU in CTRL_REG4, then the values should change even if you don't read High byte of output register.
2017-04-20 02:32 AM
Hi Miroslav,
Thank you for your time. My function to read the magnetometer values is very similar to the one I use for the accelerometer:
void
read_LSM303AGR_mag
float
MAG_XYZ_AXIS
int16_t
MAG_XYZ_AXIS_raw
3
0
uint8_t
drdy
0
uint8_t
x_mag
2
0
uint8_t
y_mag
2
0
uint8_t
z_mag
2
0
I2C_Read
I2C2
I2C_LSM3_MAG_ADRESS
1
0
I2C_LSM3_STATUS_REG_M
drdy
1
if
drdy
0x01
0x01
I2C_Read
I2C2
I2C_LSM3_MAG_ADRESS
1
0
I2C_LSM3_OUTX_L_REG_M
x_mag
2
MAG_XYZ_AXIS_raw
0
x_mag
1
8
x_mag
0
Convert
to
Gauss
MAG_XYZ_AXIS
0
float
MAG_XYZ_AXIS_raw
0
1.5
1000
if
drdy
0x02
0x02
I2C_Read
I2C2
I2C_LSM3_MAG_ADRESS
1
0
I2C_LSM3_OUTY_L_REG_M
y_mag
2
MAG_XYZ_AXIS_raw
1
y_mag
1
8
y_mag
0
Convert
to
Gauss
MAG_XYZ_AXIS
1
float
MAG_XYZ_AXIS_raw
1
1.5
1000
if
drdy
0x04
0x04
I2C_Read
I2C2
I2C_LSM3_MAG_ADRESS
1
0
I2C_LSM3_OUTZ_L_REG_M
z_mag
2
MAG_XYZ_AXIS_raw
2
z_mag
1
8
z_mag
0
Convert
to
Gauss
MAG_XYZ_AXIS
2
float
MAG_XYZ_AXIS_raw
2
1.5
1000
This one is working perfectly, the address is auto-incremented and I get correct results. I tried to only read once the ZYXDA bit, and do one reading per byte as it wasn't auto-incremented, and I get the same result as above (same value for H & L bytes of each axis). I don't really get what's happening there, it looks like the sensor is stuck and always send the same value, but it should be at least a different values for High and Low bytes.
